[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.support/front/front.c |no clones | 1 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jul 14 12:52:43 EDT 2006
Hello markus,
ANALYSIS
raster/r.support/front/front.c functions
main (Begins at: 34 Ends at: 235)
Complexity:   |      20 |     * |         |
CalledNBR:    |     108 |   *** | MONSTER |
LOC:          |     202 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-14 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
