[GRASS-QA] GRASS QA: hamish | ./grass6/lib/symbol/read.c |3 clones ( read.c )| 1 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 04:52:51 EDT 2006
Hello hamish,
ANALYSIS
lib/symbol/read.c functions
get_key_data (Begins at: 33 Ends at: 53)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
new_symbol (Begins at: 58 Ends at: 67)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
add_part (Begins at: 71 Ends at: 79)
Complexity:   |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
new_part (Begins at: 84 Ends at: 95)
LOC:          |      12 |       |      OK |
metrics are OK
add_chain (Begins at: 99 Ends at: 107)
LOC:          |       9 |       |      OK |
metrics are OK
new_chain (Begins at: 113 Ends at: 125)
LOC:          |      13 |       |      OK |
metrics are OK
add_element (Begins at: 129 Ends at: 137)
LOC:          |       9 |       |      OK |
metrics are OK
new_line (Begins at: 142 Ends at: 152)
LOC:          |      11 |       |      OK |
metrics are OK
add_point (Begins at: 156 Ends at: 166)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
new_arc (Begins at: 170 Ends at: 182)
ParamNBR:     |       6 |     * |         |
LOC:          |      13 |       |      OK |
metrics are OK
read_coor (Begins at: 186 Ends at: 209)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
err (Begins at: 213 Ends at: 225)
CalledNBR:    |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
S_read (Begins at: 228 Ends at: 420)
Complexity:   |      31 |    ** | Warning |
CalledNBR:    |      85 |   *** | MONSTER |
LOC:          |     193 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
This file has 3 potentially cloned functions:
  add_element  add_chain  add_part
In lib/symbol/read.c clones of  add_element are:
	lib/symbol/read.c  add_chain
	lib/symbol/read.c  add_part
In lib/symbol/read.c clones of  add_chain are:
	lib/symbol/read.c  add_element
In lib/symbol/read.c clones of  add_part are:
Threshold GRASS6 key metrics values at 2006-07-18 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
