[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/getgrid.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 07:23:00 EDT 2006
Hello hamish,
ANALYSIS
ps/ps.map/getgrid.c functions
getgrid (Begins at: 32 Ends at: 124)
Complexity:   |      19 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      93 |       |      OK |
metrics are OK
getgeogrid (Begins at: 129 Ends at: 218)
Complexity:   |      18 |     * |         |
CalledNBR:    |      20 |       |      OK |
LOC:          |      90 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-18 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
