[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/main.c |no clones | 3 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 08:11:46 EDT 2006
Hello hamish,
ANALYSIS
ps/ps.map/main.c functions
main (Begins at: 70 Ends at: 729)
Complexity:   |      96 |   *** | MONSTER |
CalledNBR:    |     231 |   *** | MONSTER |
LOC:          |     660 |   *** | MONSTER |
3 metric are OUT OF RANGE!
usage (Begins at: 733 Ends at: 737)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-18 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
