[GRASS-QA] GRASS QA: cho | ./grass6/vector/v.out.dxf/write_dxf.c |3
	clones ( topmodel.c write_dxf.c )| 0 monsters | 1 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Tue Jul 18 15:51:59 EDT 2006
Hello cho,
ANALYSIS
vector/v.out.dxf/write_dxf.c functions
dxf_open (Begins at: 15 Ends at: 30)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
dxf_header (Begins at: 32 Ends at: 37)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
dxf_tables (Begins at: 39 Ends at: 44)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_blocks (Begins at: 46 Ends at: 51)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_entities (Begins at: 53 Ends at: 58)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_endsec (Begins at: 60 Ends at: 65)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_eof (Begins at: 67 Ends at: 73)
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
dxf_limits (Begins at: 77 Ends at: 83)
ParamNBR:     |       4 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
dxf_linetype_table (Begins at: 87 Ends at: 92)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_layer_table (Begins at: 94 Ends at: 99)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_endtable (Begins at: 101 Ends at: 106)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_solidline (Begins at: 108 Ends at: 115)
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
dxf_layer0 (Begins at: 117 Ends at: 123)
LOC:          |       7 |       |      OK |
metrics are OK
dxf_layer (Begins at: 125 Ends at: 137)
Complexity:   |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
dxf_point (Begins at: 141 Ends at: 148)
LOC:          |       8 |       |      OK |
metrics are OK
dxf_polyline (Begins at: 150 Ends at: 158)
LOC:          |       9 |       |      OK |
metrics are OK
dxf_vertex (Begins at: 160 Ends at: 167)
LOC:          |       8 |       |      OK |
metrics are OK
dxf_text (Begins at: 169 Ends at: 178)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      10 |       |      OK |
at least 1 values are close to an outlier please consider revising code
dxf_poly_end (Begins at: 180 Ends at: 185)
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  dxf_layer  dxf_vertex  dxf_point
In vector/v.out.dxf/write_dxf.c clones of  dxf_layer are:
	visualization/nviz/src/position.c  Nget_xyrange_cmd
In vector/v.out.dxf/write_dxf.c clones of  dxf_vertex are:
	vector/v.out.dxf/write_dxf.c  dxf_point
In vector/v.out.dxf/write_dxf.c clones of  dxf_point are:
	vector/v.out.dxf/write_dxf.c  dxf_vertex
Threshold GRASS6 key metrics values at 2006-07-18 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
