[GRASS-QA] GRASS QA: cho | ./grass6/raster/r.topidx/main.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jul 18 15:51:58 EDT 2006
Hello cho,
ANALYSIS
raster/r.topidx/main.c functions
main (Begins at: 23 Ends at: 85)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-18 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
