[GRASS-QA] GRASS QA: paul | ./grass6/display/d.where/main.c |no clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jul 19 05:40:42 EDT 2006
Hello paul,
ANALYSIS
display/d.where/main.c functions
main (Begins at: 11 Ends at: 127)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      57 |    ** | Warning |
LOC:          |     117 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-19 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
