[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.mapcalc/xif.c |2 clones ( xif.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu Jul 20 08:05:01 EDT 2006
Hello markus,
ANALYSIS
raster/r.mapcalc/xif.c functions
f_if_i (Begins at: 15 Ends at: 99)
Complexity:   |      22 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      85 |       |      OK |
metrics are OK
f_if_f (Begins at: 102 Ends at: 181)
Complexity:   |      21 |     * |         |
CalledNBR:    |      18 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
f_if_d (Begins at: 184 Ends at: 263)
LOC:          |      80 |       |      OK |
metrics are OK
f_if (Begins at: 266 Ends at: 289)
Complexity:   |      12 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
c_if (Begins at: 292 Ends at: 315)
CalledNBR:    |       0 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  f_if_d  f_if_f
In raster/r.mapcalc/xif.c clones of  f_if_f are:
	raster/r.mapcalc/xif.c  f_if_d
In raster/r.mapcalc/xif.c clones of  f_if_d are:
	raster/r.mapcalc/xif.c  f_if_f
Threshold GRASS6 key metrics values at 2006-07-20 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
