[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/opencell.c |no clones
	| 0 monsters | 1 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Sat Jul 22 21:43:54 EDT 2006
Hello glynn,
ANALYSIS
lib/gis/opencell.c functions
new_fileinfo (Begins at: 113 Ends at: 175)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
G_open_cell_old (Begins at: 179 Ends at: 234)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
G__open_cell_old (Begins at: 236 Ends at: 436)
Complexity:   |      22 |     * |         |
CalledNBR:    |      42 |     * |         |
LOC:          |     201 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
G_open_cell_new (Begins at: 462 Ends at: 469)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
G_open_cell_new_random (Begins at: 471 Ends at: 478)
LOC:          |       8 |       |      OK |
metrics are OK
G_open_cell_new_uncompressed (Begins at: 480 Ends at: 487)
LOC:          |       8 |       |      OK |
metrics are OK
G_want_histogram (Begins at: 489 Ends at: 494)
CalledNBR:    |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
G_set_cell_format (Begins at: 497 Ends at: 510)
Complexity:   |       4 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
G_cellvalue_format (Begins at: 512 Ends at: 520)
LOC:          |       9 |       |      OK |
metrics are OK
G_open_fp_cell_new (Begins at: 522 Ends at: 545)
CalledNBR:    |       3 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
G_open_fp_cell_new_uncompressed (Begins at: 548 Ends at: 569)
LOC:          |      22 |       |      OK |
metrics are OK
clean_check_raster_name (Begins at: 572 Ends at: 604)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
G__open_raster_new (Begins at: 607 Ends at: 778)
Complexity:   |      17 |     * |         |
CalledNBR:    |      52 |     * |         |
LOC:          |     172 |     * |         |
metrics are OK
allocate_compress_buf (Begins at: 786 Ends at: 801)
LOC:          |      16 |       |      OK |
metrics are OK
G__reallocate_work_buf (Begins at: 805 Ends at: 819)
LOC:          |      15 |       |      OK |
metrics are OK
G__reallocate_null_buf (Begins at: 825 Ends at: 839)
LOC:          |      15 |       |      OK |
metrics are OK
G__reallocate_mask_buf (Begins at: 844 Ends at: 858)
LOC:          |      15 |       |      OK |
metrics are OK
G__reallocate_temp_buf (Begins at: 863 Ends at: 890)
LOC:          |      28 |       |      OK |
metrics are OK
G_set_fp_type (Begins at: 892 Ends at: 923)
LOC:          |      32 |       |      OK |
metrics are OK
G_raster_map_is_fp (Begins at: 925 Ends at: 939)
CalledNBR:    |       7 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
G_raster_map_type (Begins at: 941 Ends at: 960)
CalledNBR:    |       8 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
G__check_fp_type (Begins at: 963 Ends at: 1018)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
G_open_raster_new (Begins at: 1020 Ends at: 1036)
CalledNBR:    |       5 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_open_raster_new_uncompressed (Begins at: 1038 Ends at: 1068)
CalledNBR:    |       6 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
G_set_quant_rules (Begins at: 1070 Ends at: 1097)
Complexity:   |       5 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-22 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
