[GRASS-QA] GRASS QA: glynn | ./grass6/visualization/nviz/src/anim_support.c |10 clones ( rem_get.c rem_io.c rem_pad.c rem_proto.c anim_support.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu Jul 27 11:28:21 EDT 2006
Hello glynn,
ANALYSIS
visualization/nviz/src/anim_support.c functions
Nset_interp_mode_cmd (Begins at: 32 Ends at: 74)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
Nset_tension_cmd (Begins at: 76 Ends at: 121)
CalledNBR:    |       2 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
Nshowtension_start_cmd (Begins at: 123 Ends at: 140)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Nupdate_tension_cmd (Begins at: 142 Ends at: 159)
LOC:          |      18 |       |      OK |
metrics are OK
Nshowtension_stop_cmd (Begins at: 161 Ends at: 195)
LOC:          |      35 |       |      OK |
metrics are OK
Nupdate_frames_cmd (Begins at: 197 Ends at: 230)
LOC:          |      34 |       |      OK |
metrics are OK
Nset_numsteps_cmd (Begins at: 232 Ends at: 268)
Complexity:   |       3 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
Nclear_keys_cmd (Begins at: 270 Ends at: 338)
LOC:          |      69 |       |      OK |
metrics are OK
Nadd_key_cmd (Begins at: 340 Ends at: 437)
Complexity:   |      17 |     * |         |
CalledNBR:    |      19 |       |      OK |
LOC:          |      98 |       |      OK |
metrics are OK
Ndelete_key_cmd (Begins at: 439 Ends at: 486)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
Nmove_key_cmd (Begins at: 488 Ends at: 537)
CalledNBR:    |       7 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
Ndo_framestep_cmd (Begins at: 539 Ends at: 580)
LOC:          |      42 |       |      OK |
metrics are OK
Nshow_site_cmd (Begins at: 582 Ends at: 605)
LOC:          |      24 |       |      OK |
metrics are OK
Nprint_keys_cmd (Begins at: 607 Ends at: 624)
LOC:          |      18 |       |      OK |
metrics are OK
Nshow_vect_cmd (Begins at: 626 Ends at: 649)
LOC:          |      24 |       |      OK |
metrics are OK
Nshow_vol_cmd (Begins at: 651 Ends at: 674)
LOC:          |      24 |       |      OK |
metrics are OK
Nshow_lab_cmd (Begins at: 676 Ends at: 699)
LOC:          |      24 |       |      OK |
metrics are OK
Nshow_path_cmd (Begins at: 702 Ends at: 739)
LOC:          |      38 |       |      OK |
metrics are OK
Nwrite_ppm_cmd (Begins at: 741 Ends at: 772)
LOC:          |      32 |       |      OK |
metrics are OK
Nwrite_tif_cmd (Begins at: 774 Ends at: 791)
LOC:          |      18 |       |      OK |
metrics are OK
Noff_screen_cmd (Begins at: 794 Ends at: 830)
CalledNBR:    |       4 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
Ninit_mpeg_cmd (Begins at: 836 Ends at: 856)
LOC:          |      21 |       |      OK |
metrics are OK
Nwrite_mpeg_frame_cmd (Begins at: 861 Ends at: 878)
LOC:          |      18 |       |      OK |
metrics are OK
Nclose_mpeg_cmd (Begins at: 883 Ends at: 900)
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
This file has 10 potentially cloned functions:
  Nshow_lab_cmd  Nshow_vol_cmd  Nshow_vect_cmd  Nshow_site_cmd  Nclose_mpeg_cmd  Nwrite_mpeg_frame_cmd  Nwrite_tif_cmd  Nprint_keys_cmd  Nupdate_tension_cmd  Nshowtension_start_cmd
In visualization/nviz/src/anim_support.c clones of  Nshow_vol_cmd are:
	visualization/nviz/src/anim_support.c  Nshow_lab_cmd
	visualization/nviz/src/anim_support.c  Nshow_vect_cmd
	visualization/nviz/src/anim_support.c  Nshow_site_cmd
In visualization/nviz/src/anim_support.c clones of  Nwrite_tif_cmd are:
	visualization/nviz/src/anim_support.c  Nclose_mpeg_cmd
	visualization/nviz/src/anim_support.c  Nwrite_mpeg_frame_cmd
	visualization/nviz/src/anim_support.c  Nprint_keys_cmd
	visualization/nviz/src/anim_support.c  Nupdate_tension_cmd
	visualization/nviz/src/anim_support.c  Nshowtension_start_cmd
In visualization/nviz/src/anim_support.c clones of  Nprint_keys_cmd are:
	visualization/nviz/src/anim_support.c  Nwrite_tif_cmd
In visualization/nviz/src/anim_support.c clones of  Nshow_lab_cmd are:
	visualization/nviz/src/anim_support.c  Nshow_vol_cmd
In visualization/nviz/src/anim_support.c clones of  Nshow_vect_cmd are:
In visualization/nviz/src/anim_support.c clones of  Nupdate_tension_cmd are:
In visualization/nviz/src/anim_support.c clones of  Nshow_site_cmd are:
In visualization/nviz/src/anim_support.c clones of  Nclose_mpeg_cmd are:
In visualization/nviz/src/anim_support.c clones of  Nshowtension_start_cmd are:
In visualization/nviz/src/anim_support.c clones of  Nwrite_mpeg_frame_cmd are:
Threshold GRASS6 key metrics values at 2006-07-27 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     249 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
