[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jun 16 07:57:50 EDT 2006
Hello markus,
ANALYSIS
db/drivers/postgres/describe.c functions
db__driver_describe_table (Begins at: 7 Ends at: 39)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
describe_table (Begins at: 42 Ends at: 154)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      27 |       |      OK |
LOC:          |     113 |     * |         |
metrics are OK
get_column_info (Begins at: 156 Ends at: 220)
Complexity:   |      20 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      65 |       |      OK |
at least 1 values are close to an outlier please consider revising code
get_gpg_type (Begins at: 223 Ends at: 232)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-16 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
