[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jun 16 11:35:31 EDT 2006
Hello soeren,
ANALYSIS
vector/v.out.vtk/main.c functions
main (Begins at: 29 Ends at: 179)
Complexity:   |      21 |     * |         |
CalledNBR:    |      36 |     * |         |
LOC:          |     151 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-16 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
