[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( main.c main.c main.c ) 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat Jun 17 04:16:01 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/main.c functions
main (Begins at: 29 Ends at: 149)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      48 |     * |         |
LOC:          |     121 |     * |         |
metrics are OK
quit (Begins at: 151 Ends at: 171)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
error (Begins at: 173 Ends at: 196)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  quit
In imagery/i.vpoints/main.c clones of  quit are:
	imagery/i.points/main.c  quit
Threshold GRASS6 key metrics values at 2006-06-17 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
