[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.vpoints/drawcell.c |1 clones ( analyze.c drawcell.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jun 23 04:11:41 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/drawcell.c functions
drawcell (Begins at: 7 Ends at: 102)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      96 |       |      OK |
metrics are OK
re_fresh_rast (Begins at: 105 Ends at: 119)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  re_fresh_rast
In imagery/i.vpoints/drawcell.c clones of  re_fresh_rast are:
	vector/v.digit/symb.c  updated_lines_and_nodes_erase_refresh_display
Threshold GRASS6 key metrics values at 2006-06-23 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
