[GRASS-QA] GRASS QA: cho | ./grass6/display/d.profile/DumpProfile.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 27 16:08:02 EDT 2006
Hello cho,
ANALYSIS
display/d.profile/DumpProfile.c functions
WriteProfile (Begins at: 12 Ends at: 74)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      27 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
_fmt_ucat (Begins at: 82 Ends at: 110)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-27 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
