[GRASS-QA] GRASS QA: cho | ./grass6/raster/r.topmodel/file_io.c |no clones | 1 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 27 18:21:35 EDT 2006
Hello cho,
ANALYSIS
raster/r.topmodel/file_io.c functions
get_line (Begins at: 6 Ends at: 20)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
read_inputs (Begins at: 24 Ends at: 189)
Complexity:   |      17 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      49 |     * |         |
LOC:          |     166 |     * |         |
metrics are OK
write_outputs (Begins at: 193 Ends at: 413)
Complexity:   |      19 |     * |         |
CalledNBR:    |      84 |   *** | MONSTER |
LOC:          |     221 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-27 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
