[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.class/curses.c |6 clones ( curses.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 04:11:11 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.class/curses.c functions
make_window (Begins at: 16 Ends at: 36)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Begin_curses (Begins at: 38 Ends at: 59)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
End_curses (Begins at: 62 Ends at: 70)
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Suspend_curses (Begins at: 73 Ends at: 81)
CalledNBR:    |       4 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Resume_curses (Begins at: 84 Ends at: 91)
LOC:          |       8 |       |      OK |
metrics are OK
Curses_allow_interrupts (Begins at: 94 Ends at: 102)
LOC:          |       9 |       |      OK |
metrics are OK
Curses_clear_window (Begins at: 105 Ends at: 119)
Complexity:   |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Curses_outline_window (Begins at: 122 Ends at: 151)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
Curses_write_window (Begins at: 154 Ends at: 180)
Complexity:   |       6 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Curses_replot_screen (Begins at: 184 Ends at: 192)
LOC:          |       9 |       |      OK |
metrics are OK
Curses_prompt_gets (Begins at: 195 Ends at: 242)
LOC:          |      48 |       |      OK |
metrics are OK
Beep (Begins at: 244 Ends at: 249)
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Curses_getch (Begins at: 251 Ends at: 283)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
  Curses_prompt_gets  Curses_outline_window  Curses_write_window  Curses_getch  Begin_curses  Curses_clear_window
In imagery/i.class/curses.c clones of  Curses_outline_window are:
	imagery/i.ortho.photo/photo.2target/curses.c  Curses_outline_window
In imagery/i.class/curses.c clones of  Curses_prompt_gets are:
	imagery/i.ortho.photo/photo.2target/curses.c  Curses_prompt_gets
In imagery/i.class/curses.c clones of  Curses_getch are:
	imagery/i.vpoints/curses.c  Curses_getch
	imagery/i.points/curses.c  Curses_getch
	imagery/i.ortho.photo/photo.2target/curses.c  Curses_getch
	imagery/i.ortho.photo/photo.2image/curses.c  Curses_getch
In imagery/i.class/curses.c clones of  Curses_clear_window are:
	imagery/i.ortho.photo/photo.2target/curses.c  Curses_clear_window
In imagery/i.class/curses.c clones of  Begin_curses are:
	imagery/i.vpoints/curses.c  Begin_curses
	imagery/i.ortho.photo/photo.2target/curses.c  Begin_curses
	imagery/i.ortho.photo/photo.2image/curses.c  Begin_curses
In imagery/i.class/curses.c clones of  Curses_write_window are:
	imagery/i.ortho.photo/photo.2target/curses.c  Curses_write_window
Threshold GRASS6 key metrics values at 2006-06-28 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
