[GRASS-QA] GRASS QA: cho | ./grass6/vector/v.digit/vertex.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 22:56:32 EDT 2006
Hello cho,
ANALYSIS
vector/v.digit/vertex.c functions
split_line (Begins at: 15 Ends at: 138)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      54 |     * |         |
LOC:          |     124 |     * |         |
metrics are OK
rm_vertex (Begins at: 141 Ends at: 258)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      45 |     * |         |
LOC:          |     118 |     * |         |
metrics are OK
add_vertex (Begins at: 261 Ends at: 404)
Complexity:   |      15 |       |      OK |
LOC:          |     144 |     * |         |
metrics are OK
move_vertex (Begins at: 407 Ends at: 513)
CalledNBR:    |      40 |     * |         |
LOC:          |     107 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-28 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
