[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed May 3 03:28:27 EDT 2006
Hello hamish,
ANALYSIS
lib/raster/commands.c functions
R_flush (Begins at: 16 Ends at: 20)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
R_set_update_function (Begins at: 31 Ends at: 42)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
R_call_update_function (Begins at: 44 Ends at: 49)
Complexity:   |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
R_has_update_function (Begins at: 57 Ends at: 62)
ParamNBR:     |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
R_set_cancel (Begins at: 73 Ends at: 76)
LOC:          |       4 |       |      OK |
metrics are OK
R_get_cancel (Begins at: 84 Ends at: 104)
LOC:          |      21 |       |      OK |
metrics are OK
R_raster (Begins at: 106 Ends at: 138)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-03 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
