[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed May 3 04:21:36 EDT 2006
Hello hamish,
ANALYSIS
display/d.zoom/box.c functions
make_window_box (Begins at: 11 Ends at: 135)
Complexity:   |      20 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      33 |     * |         |
LOC:          |     125 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-03 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
