[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed May 3 05:12:05 EDT 2006
Hello hamish,
ANALYSIS
display/d.what.rast/main.c functions
main (Begins at: 10 Ends at: 149)
Complexity:   |      19 |     * |         |
CalledNBR:    |      57 |    ** | Warning |
LOC:          |     140 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-03 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
