[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed May 3 06:08:03 EDT 2006
Hello radim,
ANALYSIS
vector/v.transform/creat_trans.c functions
create_transform_conversion (Begins at: 35 Ends at: 43)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
create_transform_from_user (Begins at: 46 Ends at: 86)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
yes_no_quest (Begins at: 89 Ends at: 107)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
create_transform_from_file (Begins at: 111 Ends at: 137)
CalledNBR:    |       9 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-03 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
