[GRASS-QA] SOCCER LAB GRASS QA: no clones 2 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed May 3 10:19:11 EDT 2006
Hello cho,
ANALYSIS
vector/v.in.dxf/add_polyline.c functions
add_polyline (Begins at: 12 Ends at: 276)
Complexity:   |      58 |   *** | MONSTER |
CalledNBR:    |      47 |     * |         |
LOC:          |     265 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-03 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
