[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri May 5 19:38:31 EDT 2006
Hello brad,
ANALYSIS
lib/image/flsbuf.c functions
iflsbuf (Begins at: 11 Ends at: 46)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-05 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
