[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat May 6 13:20:32 EDT 2006
Hello cedric,
ANALYSIS
general/g.parser/main.c functions
translate (Begins at: 33 Ends at: 41)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
parse_toplevel (Begins at: 43 Ends at: 72)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
parse_module (Begins at: 74 Ends at: 98)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
parse_flag (Begins at: 100 Ends at: 141)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
parse_type (Begins at: 143 Ends at: 158)
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
parse_boolean (Begins at: 160 Ends at: 172)
Complexity:   |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
parse_option (Begins at: 174 Ends at: 257)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      30 |       |      OK |
LOC:          |      84 |       |      OK |
metrics are OK
main (Begins at: 259 Ends at: 403)
Complexity:   |      16 |     * |         |
CalledNBR:    |      38 |     * |         |
LOC:          |     145 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-06 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
