[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 2 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Tue May  9 03:35:44 EDT 2006
Hello glynn,
ANALYSIS
raster/r.out.vtk/main.c functions
CheckInputMaps (Begins at: 36 Ends at: 96)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
main (Begins at: 102 Ends at: 302)
Complexity:   |      22 |     * |         |
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     201 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-09 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
