[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu May 11 08:38:02 EDT 2006
Hello markus,
ANALYSIS
vector/v.db.connect/main.c functions
main (Begins at: 32 Ends at: 276)
Complexity:   |      30 |    ** | Warning |
CalledNBR:    |     118 |   *** | MONSTER |
LOC:          |     245 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-11 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
