[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri May 12 15:14:50 EDT 2006
Hello markus,
ANALYSIS
raster/r.univar2/main.c functions
main (Begins at: 22 Ends at: 229)
Complexity:   |      24 |     * |         |
CalledNBR:    |      56 |    ** | Warning |
LOC:          |     208 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-12 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
