[GRASS-QA] SOCCER LAB GRASS QA: no clones 2 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sun May 14 22:17:06 EDT 2006
Hello hamish,
ANALYSIS
display/d.rast.num/number.c functions
main (Begins at: 53 Ends at: 310)
Complexity:   |      21 |     * |         |
CalledNBR:    |      91 |   *** | MONSTER |
LOC:          |     258 |   *** | MONSTER |
2 metric are OUT OF RANGE!
draw_number (Begins at: 314 Ends at: 362)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-14 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
