[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Mon May 15 20:50:15 EDT 2006
Hello hamish,
ANALYSIS
raster/r.out.pov/main.c functions
main (Begins at: 75 Ends at: 236)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      54 |     * |         |
LOC:          |     162 |     * |         |
metrics are OK
writeHeader (Begins at: 241 Ends at: 261)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
processProfiles (Begins at: 267 Ends at: 300)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-15 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
