[GRASS-QA] SOCCER LAB GRASS QA: no clones 4 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue May 16 17:22:13 EDT 2006
Hello cho,
ANALYSIS
display/d.vect/area.c functions
darea (Begins at: 16 Ends at: 358)
Complexity:   |      49 |   *** | MONSTER |
ParamNBR:     |      13 |   *** | MONSTER |
CalledNBR:    |     100 |   *** | MONSTER |
LOC:          |     343 |   *** | MONSTER |
4 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-16 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
