[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 1 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Wed May 17 04:52:03 EDT 2006
Hello markus,
ANALYSIS
vector/v.patch/main.c functions
main (Begins at: 44 Ends at: 368)
Complexity:   |      39 |   *** | MONSTER |
CalledNBR:    |     131 |   *** | MONSTER |
LOC:          |     325 |   *** | MONSTER |
3 metric are OUT OF RANGE!
copy_records (Begins at: 371 Ends at: 465)
Complexity:   |      16 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      46 |     * |         |
LOC:          |      95 |       |      OK |
at least 1 values are close to an outlier please consider revising code
patch (Begins at: 467 Ends at: 506)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
max_cat (Begins at: 508 Ends at: 527)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-17 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
