[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( main.c ) 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Mon May 22 09:50:41 EDT 2006
Hello markus,
ANALYSIS
vector/v.surf.rst/main.c functions
main (Begins at: 127 Ends at: 789)
Complexity:   |      90 |   *** | MONSTER |
CalledNBR:    |     261 |   *** | MONSTER |
LOC:          |     663 |   *** | MONSTER |
3 metric are OUT OF RANGE!
print_tree (Begins at: 793 Ends at: 831)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
clean_fatal_error (Begins at: 835 Ends at: 862)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  clean_fatal_error
In vector/v.surf.rst/main.c clones of  clean_fatal_error are:
	raster/r.resamp.rst/main.c  clean_fatal_error
Threshold GRASS6 key metrics values at 2006-05-22 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
