[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue May 23 08:18:13 EDT 2006
Hello radim,
ANALYSIS
lib/gis/debug.c functions
G_debug (Begins at: 29 Ends at: 83)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
G_dump (Begins at: 85 Ends at: 135)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      92 |   *** | MONSTER |
LOC:          |      51 |       |      OK |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
