[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed May 24 04:18:31 EDT 2006
Hello hamish,
ANALYSIS
vector/v.voronoi/vo_main.c functions
cmp (Begins at: 35 Ends at: 68)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 34 | | OK |
metrics are OK
main (Begins at: 71 Ends at: 316)
Complexity: | 19 | * | |
CalledNBR: | 71 | ** | Warning |
LOC: | 246 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 182 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
