[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed May 24 11:22:06 EDT 2006
Hello radim,
ANALYSIS
lib/gis/list.c functions
G_set_list_hit_return (Begins at: 60 Ends at: 64)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
G_list_element (Begins at: 66 Ends at: 137)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
sigpipe_catch (Begins at: 139 Ends at: 143)
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
list_element (Begins at: 145 Ends at: 260)
Complexity:   |      19 |     * |         |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      30 |       |      OK |
LOC:          |     116 |     * |         |
metrics are OK
pstrcmp (Begins at: 262 Ends at: 275)
LOC:          |      14 |       |      OK |
metrics are OK
G_list (Begins at: 277 Ends at: 344)
Complexity:   |      12 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
G_free_list (Begins at: 346 Ends at: 358)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-24 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
