[GRASS-QA] GRASS QA: paul | ./grass6/raster/r.out.png/r.out.png.c |no clones | 1 monsters | 0 warnings
Fri Nov 3 15:11:29 EST 2006
Hello paul,
ANALYSIS
raster/r.out.png/r.out.png.c functions
main (Begins at: 48 Ends at: 351)
Complexity:   |      25 |     * |         |
CalledNBR:    |      76 |    ** | Warning |
LOC:          |     304 |   *** | MONSTER |
1 metric are OUT OF RANGE!
pnmtopng_error_handler (Begins at: 354 Ends at: 380)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
