[GRASS-QA] GRASS QA: paul | ./grass6/lib/pngdriver/Color_table.c |no clones | 0 monsters | 0 warnings
Fri Nov 3 15:31:43 EST 2006
Hello paul,
ANALYSIS
lib/pngdriver/Color_table.c functions
set_color (Begins at: 11 Ends at: 17)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
init_colors_rgb (Begins at: 19 Ends at: 22)
ParamNBR:     |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
init_colors_indexed (Begins at: 24 Ends at: 65)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
init_color_table (Begins at: 67 Ends at: 85)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
get_color_rgb (Begins at: 87 Ends at: 90)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
get_color_indexed (Begins at: 92 Ends at: 98)
LOC:          |       7 |       |      OK |
metrics are OK
PNG_lookup_color (Begins at: 100 Ends at: 105)
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
