[GRASS-QA] GRASS QA: brad | ./grass6/lib/cdhc/cvmw2e.c |no clones | 0 monsters | 0 warnings
Fri Nov 3 23:17:01 EST 2006
Hello brad,
ANALYSIS
lib/cdhc/cvmw2e.c functions
cramer_von_mises_exp (Begins at: 7 Ends at: 53)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
