[GRASS-QA] GRASS QA: brad | ./grass6/lib/cdhc/kse.c |1 clones ( kse.c )| 0 monsters | 0 warnings
Fri Nov 3 23:17:02 EST 2006
Hello brad,
ANALYSIS
lib/cdhc/kse.c functions
kolmogorov_smirnov_exp (Begins at: 7 Ends at: 23)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In lib/cdhc/kse.c clones of  kolmogorov_smirnov_exp are:
	FILE_PATH  FNAME
	lib/cdhc/kuiprsve.c  kuipers_v_exp
Threshold GRASS6 key metrics values at 2006-11-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
