[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.in.xyz/main.c |no clones | 3 monsters | 0 warnings
Sat Nov 4 23:22:38 EST 2006
Hello glynn,
ANALYSIS
raster/r.in.xyz/main.c functions
main (Begins at: 26 Ends at: 613)
Complexity:   |      86 |   *** | MONSTER |
CalledNBR:    |     202 |   *** | MONSTER |
LOC:          |     588 |   *** | MONSTER |
3 metric are OUT OF RANGE!
scan_bounds (Begins at: 617 Ends at: 709)
Complexity:   |      17 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      24 |       |      OK |
LOC:          |      93 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-04 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
