[GRASS-QA] GRASS QA: brad | ./grass6/lib/datetime/incr1.c |no clones | 1 monsters | 0 warnings
Tue Nov 7 04:40:57 EST 2006
Hello brad,
ANALYSIS
lib/datetime/incr1.c functions
datetime_increment (Begins at: 67 Ends at: 153)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      87 |       |      OK |
metrics are OK
_datetime_subtract_field (Begins at: 155 Ends at: 372)
Complexity:   |      41 |   *** | MONSTER |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |     218 |    ** | Warning |
1 metric are OUT OF RANGE!
_datetime_carry (Begins at: 379 Ends at: 467)
Complexity:   |      20 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |      89 |       |      OK |
metrics are OK
_datetime_add_field (Begins at: 469 Ends at: 497)
Complexity:   |       9 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
