[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/mapset_msc.c |no clones | 0 monsters | 0 warnings
Fri Nov 10 05:34:32 EST 2006
Hello brad,
ANALYSIS
lib/gis/mapset_msc.c functions
G__make_mapset_element (Begins at: 24 Ends at: 83)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      60 |       |      OK |
metrics are OK
G__mapset_permissions (Begins at: 85 Ends at: 112)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
G__mapset_permissions2 (Begins at: 114 Ends at: 132)
ParamNBR:     |       3 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-10 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
