[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/rhumbline.c |no clones | 0 monsters | 0 warnings
Fri Nov 10 05:34:33 EST 2006
Hello brad,
ANALYSIS
lib/gis/rhumbline.c functions
G_begin_rhumbline_equation (Begins at: 30 Ends at: 60)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
G_rhumbline_lat_from_lon (Begins at: 64 Ends at: 83)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
adjust_lat (Begins at: 85 Ends at: 91)
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-10 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
