[GRASS-QA] GRASS QA: martinl | ./grass6/lib/gis/getl.c |no clones | 0 monsters | 0 warnings
Fri Nov 10 15:18:50 EST 2006
Hello martinl,
ANALYSIS
lib/gis/getl.c functions
G_getl (Begins at: 17 Ends at: 50)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
G_getl2 (Begins at: 52 Ends at: 89)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-10 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
