[GRASS-QA] GRASS QA: markus | ./grass6/vector/lidar/v.outlier/main.c |no clones | 2 monsters | 0 warnings
Sat Nov 11 12:02:09 EST 2006
Hello markus,
ANALYSIS
vector/lidar/v.outlier/main.c functions
main (Begins at: 37 Ends at: 338)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |     124 |   *** | MONSTER |
LOC:          |     302 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
