[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/gisinit.c |no clones | 0 monsters | 0 warnings
Mon Nov 13 03:56:55 EST 2006
Hello markus,
ANALYSIS
lib/gis/gisinit.c functions
G_gisinit (Begins at: 22 Ends at: 53)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
G_no_gisinit (Begins at: 55 Ends at: 63)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
G__check_gisinit (Begins at: 65 Ends at: 71)
CalledNBR:    |       4 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
gisinit (Begins at: 73 Ends at: 104)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
