[GRASS-QA] GRASS QA: paul | ./grass6/lib/gis/progrm_nme.c |no clones | 0 monsters | 0 warnings
Tue Nov 14 11:32:54 EST 2006
Hello paul,
ANALYSIS
lib/gis/progrm_nme.c functions
G_program_name (Begins at: 32 Ends at: 35)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G_set_program_name (Begins at: 37 Ends at: 54)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-14 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
