[GRASS-QA] GRASS QA: hamish | ./grass6/lib/imagery/list_subgp.c |no clones | 0 monsters | 0 warnings
Wed Nov 15 03:26:44 EST 2006
Hello hamish,
ANALYSIS
lib/imagery/list_subgp.c functions
I_list_subgroup (Begins at: 13 Ends at: 67)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
I_list_subgroup_simple (Begins at: 69 Ends at: 73)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
