[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.kappa/calc_kappa.c |no clones | 0 monsters | 0 warnings
Wed Nov 15 14:39:56 EST 2006
Hello jachym,
ANALYSIS
raster/r.kappa/calc_kappa.c functions
calc_kappa (Begins at: 8 Ends at: 109)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      27 |       |      OK |
LOC:          |     102 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
